Sportbike_Pilot
Flight distance : 10278435 ft
mpwobbly Posted at 2017-9-28 15:43
I was watching a video yesterday on Youtube and the bottom sensors ARE working in sports mode - this guy was able to prove it a number of times because it was a surprise to him too - if I can find the video link I'll put it up but not all the sensors are off in sports mode (apparently). I'm new to the Mavic Pro so I don't want to sound like I'm the expert but the video was interesting.
Would you re-check and post that link right on here?
When I turn on (S)port mode, the sensors icon is lit in red. This means inactive. I've even tested having the Mavic head straight into my direction and it doesn't stop nor any alerts which indicates inactivity.
For reference see below.
Straight from MP Manual:
S-mode (Sport) - The aircraft is using GPS for positioning. As Forward and Downward Vision Systems are disabled, the aircraft will not be able to sense and avoid obstacles when in Sport Mode. Ground Station and the Intelligent Flight functions are also not available in Sport Mode.
Note: Aircraft responses are optimized for agility and speed making it more responsive to stick movements.
The Forward Vision System is disabled in S-mode (Sport), which means the aircraft will not be able to automatically avoid obstacles on its route.
The aircraft’s maximum speed and braking distance are signi cantly increased in S-mode (Sport). A minimum braking distance of 30 meters is required in windless conditions. Descending speed is signi cantly increased in S-mode (Sport).
The aircraft’s responsiveness is signicantly increased in S-mode (Sport), which means a small stick movement on the remote controller will translate into a large travel distance of the aircraft. Be vigilant and maintain adequate maneuvering space during flight. |
