I added a zoom effect in Premiere Pro by adding an adjustment layer. When I play the video while the effect is doing its job (so the transition), the video isnt as sharp as the video without the adjustment layer on top of it. Any suggestions?
Might sound a bit confusing; I followed this tut: It's about the piece of footage after the transition.
You can always try shooting in a higher resolution although computer processing information can be an issue. What type of aircraft are you using and what is your resolution?
DJI-Mark Posted at 2017-9-25 06:47
