First Crash with my Mavic =( can it be repaired?
1115 10 2017-9-25
Cloud56
Brazil
What I thought would never happen, happened.
My hardshell case didn't arrive yet, so I carry my Mavic unprotected on my backpack, due to worry I always turn it on a little bit to make sure everything is ok when I get home from a trip. But this time I was in my girlfriend's house and seeing how amazed she was looking at it, I decided to fly a bit more in the house, went close to wall, the plan was to turn 180º (the wall was in front of the drone) and get back,  but suddently, due to ATTI mode, when I started yawing, at around 90 degrees, it decided to go right and hit the wall... all by itself.
I swapped the 2 props that hit the wall and locked the gimbal back in that bottom piece, turned it on and everything was fine, but then she showed me a dent on 1 of the motors metal protection thing (I wish she hadn't), I'll post a picture when I get home.
Can only the round protection around the motor be replaced? or does the whole arm have to be replaced?
2017-9-25
DJI-Mark
We would have to examine the aircraft to make a determination on what needs to be replaced. Please contact customer support for further evaluation.
2017-9-25
Mari
Flight distance : 1308780 ft
Your girlfriend would be more amazed when you had decided to fly outside instead of inside.... It is very hard to control the MP when flying inside on ATTI-mode, even if you have started in GPS-mode, be aware that ATTI-mode will kick in when GPS fails and you have to control your MP all by yourself.
My fist flight indoor was a succes, so I thought I could do it again... Bad mistake, it allmost cost me the MP, was fighting the controls to avoid flying into the wall... Landing succeeded and I promised myself NEVER, NEVER, NEVER to fly indoor again...
2017-9-25
Sportbike_Pilot
Flight distance : 10278435 ft
Mari Posted at 2017-9-25 09:56
"Bad mistake, it allmost cost me the MP, was fighting the controls to avoid flying into the wall... Landing succeeded and I promised myself NEVER, NEVER, NEVER to fly indoor again..."
Ditto ! experience the same thing and it was like trying to control a wild horse...took off while I tried my best to control and land. Guess what? I never did it again.
2017-9-25
$gambino$
Flight distance : 1563980 ft
Mavic flys great indoors. Even in atti mode should be in opti mode that was sufficient lighting so far have done about 10 flights in my basement
2017-9-25
MARSAN
Flight distance : 966978 ft
Belgium
Even if the arm with motor will have to be replaced, it'll only cost +/- US$ 33 without shipping fees.
Provided you can replace it yourself.
If you're uncomfortable with the fact to do it yourself, ask DJI support.
2017-9-25
DJI Diana
Flight distance : 2408 ft
Sorry for the crash, have you contacted the Support? You can refer to the link below to contact them. They'll start a case for you.
http://www.dji.com/support
2017-9-25
Cloud56
Brazil
DJI Diana Posted at 2017-9-25 20:27
I haven't, I doubt there will be support for my country, but I'll give it a try.
Here are the pictures:
https://drive.google.com/open?id=0B8zrzryv-m0lT1dlYnFveXU5NGs
https://drive.google.com/open?id ... -m0lOW45MWRqU1lYQUk
https://drive.google.com/open?id=0B8zrzryv-m0lQlVScHFyc2lJNjA
Is it still ok to fly?
2017-9-26
Cloud56
Brazil
Fix for pic number 2: https://drive.google.com/open?id=0B8zrzryv-m0lSU1fNWx6MkFZdWM
2017-9-26
Cloud56
Brazil
Yep, I felt pretty stupid after it crashed =(.
Never flying indoors again.
2017-9-26
DJI Diana
Cloud56 Posted at 2017-9-26 14:11
Please do an overall check first. If I were you, I would not fly it at this moment. If it is possible, I would send it for diagnosis.
2017-9-26
