jimhare
Flight distance : 239035 ft
fans4f8954b4 Posted at 2017-6-8 03:30
Hi Jim, again as you usually do ,awesome video and thanks to post, you know something, each time I look at your videos, I realize how bad are mine. I have a big problem when I shoot my videos, the images are jumping when I pan the camera , tried to change the settings but nothing help, you might have any idea. Thanks in advance. Raf from Paris
Hi Raf,
Thank you for your comments, much appreciated!
If your images stutter as you pan it's because you are panning too fast for your shutter speed.
To have a cinematic image your shutter speed should be 2 x your frame rate so if you shoot 25 frames per second your shutter should be 1/50 but it means you have to pan quite slowly.
If you want to pan quickly you should use a faster frame rate like 50 frames per second.
Experiment with the settings and find out what works best for you.
Hope this makes sense and helps!
Jim
