maps
1804 9 2017-9-26
AnzacJack
Flight distance : 3501650 ft
[size=14.6667px]I got my Crystalsky 7.85 today and i cant get maps on it. Ive read all the solutions posted previously but nothing working. all i have is  a home point on a white screen
[size=14.6667px]
  • it is latest version
  • i have reset it and rebooted (3 times now)
  • It is definitely connected to wifi as i can use the browser and sync my flight logs etc
  • i have tried both home wifi and hotspotting my phonb
  • disabled mainland china settings
  • set correct timezone
  • tried to download offline maps via go4 using the 3 bars at top rh corner,  but this tells me network unavailable
  • checked the drone by connecting ipad and my android phone, both clearly show maps
Im at a loss and quite annoyed (just dropped a grand on this thing)
any help would be very much appreciated
2017-9-26
Sorry for the troubles you are experiencing, please try to reset CrystaSky to factory default in System Settings.
2017-9-26
rparge
Flight distance : 173852 ft
I had to try several times to get them, got the same error, but finally got through.
2017-9-26
Keule
Flight distance : 3733015 ft
After resetting to factory defaults, be sure to NOT connect to WiFi firsthand!
- Manually set Date/Time and your Timezone first
- Disable China Mainland maps
- Then connect to your WiFi network.
- Download within GO4 your offline maps for your region.
Do not deviate in the sequence from above steps.
Hope that helps.
Regards,
K.
2017-9-26
AnzacJack
Keule Posted at 2017-9-26 11:24
could not do it in that order, as when i reset, then manually set time i try to go into GO4 app to change China mainland setting but you have to log in first which means turning on wifi
2017-9-26
AnzacJack
after numerous attempts of resetting and reloading i now seem to have sateliite maps. It still shows a white blank for the normal map (street directory style) but i can live with this.
seems to be such an annoying thing for such an expensive bit of tech
2017-9-26
AnzacJack
does anyone know where the maps are actually stored withing the GO4 app files. I am wondering if i can just manually transfer them there from another android?
2017-9-26
AnzacJack Posted at 2017-9-26 16:28
The map cannot be transferred, but for Android device, there is offline maps can be downloaded.
Please click three horizontal lines on the upper right corner of the APP interface to find it.
2017-9-28
AnzacJack
DJI Mindy Posted at 2017-9-28 00:29
I have clicked the 3 horizontal bars and it tells me it cannot find network (I did say that in my original post)
2017-9-28
Chuck1906
Flight distance : 3574003 ft
This is what I did to get the maps to show up. If you are in the USA, do a factory reset on the C.S. then reboot it. Once you power it up, your map should pop up. It took me a day or so of fooling around with it to figure that out.
2017-9-29
