Labroides
Flight distance : 9991457 ft
fans8a1d5757 Posted at 2017-9-27 05:31
Are you referring AG Column to this section If yes it appears I back off the throttle when the RTH starts. Also: how can a P3S brake to avoid an obstacle? It doesn't have sensors, correct?
Plus the GPS map shows I am in the middle of a channel 63' over water. What obstacle?
Yes, column AG is throttle data
No, it doesn' show you backing off until well after RTH has initiated. (1024 is the centre stick position - 1684 is full forward)
You started pushing the left stick forward at 10.43 and held it until 10:48.4.
RTH initiated in the middle of that at 10:46
Obviously it a false alarm.
If you had a P4 pro with sensors, the downward sensors only work to 10 metres but the forward looking sensors work further than that |
