Gwen1405
Flight distance : 2543038 ft
Belgium
Hi,
As a new owner of an Inspire 2 (2 weeks later), I proceed to the firmware upgrade after the receipt. I have also a P4, and the upgrade procedure was painful (not the procedure but only side effects).
So after calibration and other fine tunes, I decide to test it outdoor on a drone field. So ATTI is good and Sportt mode too, but for the P-Mode the flight is « jerky ». The flight fluidity is not linear, I have a decrease, increase speed impression (The noise also is «bad » in P-Mode)
And I have enough satellites, no wind condition, vps calibrated, ...
So do you have the same issue (due to firmware version)?
Do you have the same behaviour with your I2 ?
Kind regards,
Gwen
