CAMERA NOT KEEPING UP WITH FLIGHT
FREDDY71
THE CAMERA ON MY INSPIRE 1 IS SOMTIMES NOT KEEPING UP WITH FLIGHT AND SAYS DISCONNECTED, THEN IT SEEMS TO REFRESH AND IN A COUPLE OF MINUTES DO IT AGAIN. WHATS GOING ON? THIS STARTED AFTER INSTALLING THE LATEST FIRMWARE.
2017-9-26
Highasakite
Flight distance : 1423930 ft
FREDDY71, what device are you using? How far away are you flying?  There are a number of things that can cause those symptoms. Safety First! Ken.
2017-9-26
DJI-Mark
Does the remote disconnect as well? Have you tried reinstalling the app?
2017-9-26
SPS Aerial Tech
Flight distance : 506421 ft
I'm having a similar issue (not sure if its literally the same thing).
I'm using an Inspire 1 V2 with the X3 gimbal attached. Sometimes in flight I will lose the ability to take photos. The camera is still feeding images into my iPad mini 4 and the remote is still connected, but the camera settings read out "N/A" for your shutter speed/ISO etc.. Upon this error occurring during flight. I immediately land and turn off the drone, then turn it back on again and the problem is fixed..
Very annoying... Does this sound familiar?
2017-9-26
DJI Elektra
SPS Aerial Tech Posted at 2017-9-26 14:38
if the Ipad still had image at that time, the problem may caused by SD card. Please try to format you SD with your PC or change a SD card for check. Keep us updated, if the problem remains.
2017-9-26
DJI Elektra
FREDDY, when you turned on your AC, would it started self checking? Please ensure that the connection between the camera and your drone is well connected.
You can check the pin above your camera. Please provide me the screenshot of your app with the error message. Thanks.
2017-9-26
Donnie *
Flight distance : 3636782 ft
What are you using for the Go app ?  The system needs a fast processor and older go app devices may not be able to keep up.  This is quite common after an update to have a sudden loss of  smooth video as the new FW is taking more and more power .
If you can get and I pad pro  ( standard size ) with a A9 or A10 processor -  this is the gold standard in my book  and then test and see if the lagging slow video goes away , if it does, that is the problem .
donnie
2017-9-27
