SAR Steve
fans621af22f Posted at 2018-1-27 06:40
Live streaming on Pilot is possible to a RTMP server but it is extremely unstable. It disconnects after 20-30 seconds and says bad network environment even at lowest bit rate. Go 4 streams in same place without a problem. Also, while streaming in Pilot, the Pilot app crashed and also caused Cendence to reset. VERY disappointed about system stability after spending $30K+ on M210RTK w/XT and Z30. Get your act together, DJI!!!!!
BTW, I posted the original message but found a great solution for streaming using an inexpensive Webcaster X2 box. I go HDMI out from the Crystal Sky into the streaming box and then out over a hotspot to a private unlisted YouTube channel. Works every time. |
