Mavic QuickShot - Can I Record On Return Path
4141 8 2017-9-26
calmari
Flight distance : 64944 ft
When flying the Mavic using a QuickShot mode, after it completes the QuickShot sequence it returns on the same flight path. I think it stops recording automatically at the end of the outward flight. Is it possible to record footage on the return path? Or is it locked off?
Something I have not tried yet but I am keen to know.
2017-9-26
DJI Thor
Flight distance : 13602 ft
The Quickshot mode only supports recording when the outward flight. If you want, you can manually click the record button when it returns, but that is only the recording, not a Quickshot video.
2017-9-26
calmari
DJI Thor Posted at 2017-9-26 18:34
Okay thanks that is what I want to do. I’m confused though what is the difference between a recording and a QuickShot video?
2017-9-27
DJI Thor
calmari Posted at 2017-9-27 01:05
A Quickshot video is no matter how long the record time it would be during the flight, it will generate a 10-second video in the end, during the normal recording, you will get a video length that it supposes to have.
2017-9-28
calmari
Okay, that doesn't appear to work. I cannot set it to record on the return path. So if that is what is supposed to happen then there is a bug somewhere.
2017-9-28
calmari
DJI Thor Posted at 2017-9-28 00:46
Okay thanks but again that doesn't appear to happen either. I get a video the full duration of the shot sequence. I also saw it mentioned as well that the Mavic returns to home on the same path. That sort of  happens in 'Dronie' mode but in 'Helix' mode it flies to the start point in a straight line from where it finished the QuickShot manouvre.
2017-9-28
DJI Thor
calmari Posted at 2017-9-28 05:32
Oh, it is my bad that I should have made it more clear. I do it when I cancelled the return, clicked the record and took it back manually. But I will try not to cancel the return, just press the record bottom of the RC for the next time.
2017-9-29
fans5fe3de0f
please make it possible to record the Return Path, or to do a REVERSE Quickshot. as creatively it is SOMETIMEs ;VERY IMPORTANT to ARRIVE at the point of interest in a moving forward in time.
2020-7-8
djiuser_OB4GFYSodngG
I would be nice if you can configure the direction  of the quick shot because when you reverse it in post cars and people move backwards
2022-5-11
