Inspire 1 Zenmuse X3 camera mount work w/ LB2
1668 7 2017-9-26
fans36b5aa42
Flight distance : 15207 ft
I have an extra  Inspire 1 Zenmuse X3 camera mount.  (Building a custom Rig)  Will the  Inspire mount connect directly to a LightBridge 2 ?  Or do I have to get the Matrice 600 Series - Zenmuse X3/X5/XT/Z3 Series Gimbal Mounting Bracket.
Chris
2017-9-26
WiSi-Testpilot
You need the Matrice 600 Series - Zenmuse X3/X5/XT/Z3 Series Gimbal Mounting Bracket,
the Lightbridge 2 and the A3 or N3 flight controller.
I have shortened the bracket, see picture.
https://forum.dji.com/forum.php? ... D318%26typeid%3D318
see this link for more pictures.
Best regards,
Wilhelm
2017-9-27
fans36b5aa42
WiSi-Testpilot Posted at 2017-9-27 14:10
Thanks for the Reply.   Was hoping that I would not have to spend $170 more dollars.
2017-9-27
fans36b5aa42
What Voltage are using to power the M600 gimbal, and how are you doing it??   (N3 + Lightbridge2.  NOT used on M600 rig)
2017-10-15
WiSi-Testpilot
I run it with 4S and have connected it directly to the Lipo. If I remember correctly (read in RCG) you can also use 6S.
Best regards,
Wilhelm
2017-10-15
fans36b5aa42
WiSi-Testpilot Posted at 2017-10-15 23:50
Best regards,
Wilhelm
Thanks for the additional info, I know the connection on the M600 is 18 volts. I am running a 6s and was not sure if the extra 4 volts would harm the Gimbal if connected directly to 22.2 volts. Sorry for the ignorance what is "RCG"
Chris
2017-10-16
WiSi-Testpilot
It is the RC Group forum. There are many threads concerning DJI products.
There you may ask your question again.
2017-10-16
fans36b5aa42
fans36b5aa42 Posted at 2017-10-16 01:54
Chris
From all my research the M600 gimbal can be connected directly to a 6s battery.
2017-10-20
