jmb63
Flight distance : 7009439 ft
fans1fa2df2f Posted at 12-18 18:39
Hi guys, same story I’m having issues with the grainy footage with both pictures and video, ( I’m not using a SD card if that even matters). I’ve seen some amazing footage from people I just wanted to know is there something doing wrong or is this just the standard of the DJI spark? Would appreciate any advice or thoughts
Cheers
You mention NOT using an SD card? If that is the case, you will never see a "good" image.
Anything that you are seeing in the app is not a good quality image.
The Spark records the " good" images ONLY on the SD card!
How are you retrieving these videos/pictures?
The BEST quality/resolution is directly from the SD card (in the Spark) Which would have to be inserted into either a PC or an adapter (to read it on your phone/device).
Anything that is on the phone/device is a low quality/resolution preview that is cached in the phones memory.
It is possible to download "good" images to your device/phone, but they have to have been recorded onto the SD card first.
I hope that helps.
I suggest you take a little time and research the function since that info is not clear at first!
