Engines don´t start
2400 33 2015-4-5
hakan
Sweden
Hello, new here - very interesting forum and discussions!
I am also new to flying Phantom vision 2 + - started to learn by making a small flight - but (of course) ended up in a bush, one prop was chipped and the battery went out of the Phantom.
Since then it is not possible to start at all, even if all lights and connections are working.
I have downloded the latest software for everything, and recalibrated the RC.
When I start up the Phantom it connects to the RC, and to the mobile phone I am using. The props make a small move when RC is connected. All seems normal. I make calibration, it all follows what is said in the manual regarding blinking and sounds and all. Then I pull the sticks on the RC dow ti the corners to make it start - nothing happens nor can be heard (except for my growning...).
Any suggestions?
Thanks in advance! /Håkan
2015-4-5
OMOJESU
Try recalibrating your remote controller
2015-4-6
hakan
Sweden
Hi Omojesu! Thanks for your suggestion! But - I have done that several times...
2015-4-6
johnwarr
Flight distance : 6467 ft
A crash that was hard enough to have the battery pop out is quite serious.
Although you say all Is normal regarding the LED's and sounds, I would suspect that Is not the case.
How many sats are showing in the app ?
2015-4-6
nrgwise
As John said, a crash hard enough to eject the battery is serious.  I would open the shell and make sure everything is connected and appears solid.  If all appears well, I would also perform an IMU cal after a crash that hard.
2015-4-6
Northofthe49th
Hak,
By your post it sounds like you did upgrades after your crash?
Check out the below post and compare your screens to see if everything looks same.
Some folks have also mentioned their "mode" changed, check to see it is correct in the Assistant.
If possible, a short video of your start-up lights confirming all are correct would help.
http://forum.dji.com/forum.php?m ... %2Bpost&lang=en
2015-4-6
acenothing
Flight distance : 112185 ft
"Chipped a prop..." = Damaged motor or burnt ESC
2015-4-6
Northofthe49th
acenothing Posted at 2015-4-7 01:05
Definitely the ESC for the motor with the broken prop would be suspect!
Also, make sure both S1 and S2 are in up position otherwise it will never start.
FYI..I descintegrated a prop on my second flight on Jan 1, had to replace prop only and have 70+ full batteries through the Phantom since...
2015-4-6
hakan
Sweden
johnwarr@live.c Posted at 2015-4-6 20:38
Although you say all Is n ...
Hi John, thanks for your reply. I was very surprised that the battery popped out, since it was not t all a hard crash. It "fell" into the bush, more or less... But on the other hand I dont have so much experience to know what is "hard" and what is "soft" in these cases.
Regarding sats - it shows 6 - 8 , no problems there-
2015-4-6
hakan
Sweden
Northofthe49th Posted at 2015-4-6 22:29
Hak,
Check out the below post and com ...
Hi North, Thanks for your reply. At a quick glance the settings are as shown. I understand that "norm" could be switched, but they have not. I will try to provide a video of the start up sequence when we have daylight over here
2015-4-6
hakan
Sweden
Hi Ace, Thanks or your reply! What is ESC? (I understand it is something vital, but my english is not good enough to guess what it is... How do I know if the motor is damaged? They spin easily by hand.
2015-4-6
hakan
Sweden
nrgwise@gmail.c Posted at 2015-4-6 21:35
As John said, a crash hard enough to eject the battery is serious.  I would open the shell and make  ...
Hi nrgwise, Thansk for your reply. What is an IMU cal, when spelled out?  As I have mentioned, Wnglish is not my first language, so things are not all clear for me... Sorry for that...
2015-4-6
nrgwise
In the assist software, under Tools you will find IMU calibration/Advanced IMU calibration.  Make sure the quad is level and not near any metal (just a precaution).  You may get a message Too hot. Click ok and let it continue.  It is done when you get a green check.
Inertial Measurement Unit
2015-4-6
hakan
Sweden
Hello again, I made a short video of the startup procedure, but I have to edit it for size in the morning. However I took a screen image
from my cell phone while it was connected. After takiong this shot, I got 6 sats and the lights blinked green. When I made took the controls down left and down right the quad blinked fast red, then got back to green.
I am a bit puzzled about fkying time set to 0, and also connection as "n/a" since I had a perfect connection...
Warm regards from a cold night out! /Håkan
2015-4-6
Northofthe49th
Fast red is a critical low battery warning, remove battery, check for contamination on the terminals and firmly reseat and try again...
If no go, Do you have another battery to try?
If not, check your battery status in the Phantom Vision Assistant software...see if it reads normal as you mentioned it popped out, did it hit the ground hard as it may be damaged.
Lots of good information on here...Phantomhelp.com
Look under manuals for the "ultimate Phantom Guide" and references for "common acronyms"...
2015-4-6
hakan
Sweden
HI again North, thakns for taking time to answer me. No, it did not hit hard fell like 5 dm on to to lawn. All status in Vision Assistent seems to be ok, but I will check again more closely. Also will try to clean the battery. Thanks - will update when all things are tried again!
2015-4-7
jmtw000
hakan@tecknolog Posted at 2015-4-7 05:10
Hello again, I made a short video of the startup procedure, but I have to edit it for size in the mo ...
Hello hakan,
    I have seen similar behavior when the GPS module is disconnected. However, since you're seeing satellites in the app this can't entirely be the case. I wonder if the GPS  module is still connected to the wifi module allowing you to see satellites in the app but the cable connecting it to the flight controller came loose during the crash. I'd open the shell and check that there are no loose cables.
2015-4-7
hakan
Sweden
Hi Jm, Thanks for replying! Me opening the shell... I am not an under-the-shell-looking-man...
But as a last thing I will do this...Thanks for the advice! I did not fully understand what could be wrong, regarding to your post - I am sorry, my technical English is not very fluent... If you have time, please tell me again - in Swedish if you can..
2015-4-7
hakan
Sweden
2015-4-7
hakan
Sweden
Northofthe49th Posted at 2015-4-7 05:20
Fast red is a critical low battery warning, remove battery, check for contamination on the terminals ...
Hello again! I cannot find anything incorrect regarding the battery, but on the other hand I don´t fully know what all readings should be to be "normal". There was no dirt nor any other issues with the battery case itself. Does the readings seem to be ok to you? /regards Håkan
Barrey check
Barrey check
2015-4-7
Gerry1124
Have you downloaded the latest version of the DJI APP for your phone?
2015-4-7
hakan
Sweden
Gerry1124 Posted at 2015-4-8 00:44
Hi Gerry, Yes the app is up to date.
2015-4-7
hakan
Sweden
Hak,
Now I have managed to put the video togehter, showing the upstart procedure. It was during this upstart the screen image from the cell phone was taken (see above in the post).
https://www.dropbox.com/s/gr5e9xrh11gynae/a0000108.mp4?dl=0
I also found that there was a crash report in the dji-area of the phone. However, if this is a crash of app report or of aircraft, I dont know:
The text in it was as follows:
java.lang.NullPointerException
at com.dji.uuid.UuidService.isWifiOk(Unknown Source)
at com.dji.uuid.UuidService.access$3(Unknown Source)
at com.dji.uuid.UuidService$2.run(Unknown Source)
at java.lang.Thread.run(Thread.java:841)
2015-4-7
CapitAn
Hi Hakan. Sorry l have no input to help with your issue, l'm a new owner myself and l'm still on the learning curve.
l did notice though that the second part of your calibration was strange. When you put the phantom on its side, you spun it on an axis from its central point, and l'm pretty sure you're supposed to turn it laterally, in a circle.
2015-4-7
Gerry1124
CapitAn Posted at 2015-4-8 04:21
Hi Hakan. Sorry l have no input to help with your issue, l'm a new owner myself and l'm still on the ...
You're right Capitan, the first turn is ok, the second turn, the lens needs to be pointed to the ground and rotate around that.
2015-4-7
hakan
Sweden
Thanks Captain and Gerry for your input. I did not really get what the second turn should be like (more due to my bad english, not becasue your explanation!) I will take a closer look in the manual. However, I get the correct lights after the second calibration, or don´t I? And the map in my phone show correct location. But I will look into it more closely!
Still - does this have effect on the Phantom not starting the engines and giving me red lights instead?
Warm regards, Håkan
2015-4-7
Gerry1124
hakan@tecknolog Posted at 2015-4-8 13:42
Thanks Captain and Gerry for your input. I did not really get what the second turn should be like  ...
Here is the correct compass calibration.
make sure both switches are in the top position before you start the motors.
2015-4-7
hakan
Sweden
Everybody, thanks a lot for taking the time to answer my questions and to help me out. I discharged the battery to almost 0, and then made the calibration the correct way. Now everything went ok and the Phantom engines started! I did not take off, but it seems to work. Now we just have to think about what made this sucessful (and for me to fly without crashing...). Warm regards to you alla! /Håkan
2015-4-8
Gerry1124
hakan@tecknolog Posted at 2015-4-8 17:21
Everybody, thanks a lot for taking the time to answer my questions and to help me out. I discharged  ...
That's good to hear
Happy Flying!
2015-4-8
jmtw000
So, an incorrect compass calibration will prevent the motors from starting? I'm going to have to see if I can reproduce that. That's useful to know.
2015-4-8
Northofthe49th
Great work folks,
A picture is worth a thousand words and a video is..."Priceless"!
Happy flying Hak
2015-4-8
hakan
Sweden
Firstly: Thanks again to all particpating in this thread!
Secondly: Here is a more compact version about all things I did, to make the issue disappear. It is always better do do one thing after the other, I guess, to be sure of what caused the issue - but in my eargeness I did several things...
1.  Recalibrated compass in correct way
2. Discharged the battery until only one green LED was flashing
3. Installed all new updates.
I did other things too, but after doing them, I got the same result - no fly.
After having discharged the battery and installed new updates, it looked ok in my phone - but I did not try to start at this point. Then I recalibrated the compass too, and all systems were go!
I have had lift off four times (and made a proper landing once...) and it seems to be working fine. I had a "drift off" at one stage, letting go of the controls did not make the Phantom hoover, it instead drifted away (a cross the neighbour fence...) I guess (?) it lost the sats - had 8 when I lfted off, but only 4 when "landing" . I will be in a larger field from now on to practice...
Warm regards to you all, /Håkan
2015-4-11
eman_vg
Flight distance : 1015440 ft
Maybe check it out under the hood and see.
2018-1-18
eman_vg
Oh I just realized how old this post is. Whoops. #TBT
2018-1-18
