prop ballancering
1191 17 2017-9-27
LarsPlovmann
Flight distance : 696437 ft
Denmark
Hey..
Since I got my inspire 1 PRO i cant ballance my props...  you know...  the PRO props has a oval hole, and I cant find anything fit it
What to do ??
Regards
Lars
2017-9-27
fansa84fe8a4
Flight distance : 3 ft
This: https://www.amazon.com/EJH-Preci ... spire/dp/B01AOHVRGE
and this: https://www.amazon.com/Dubro-Pro ... words=prop+balancer
2017-9-27
LarsPlovmann
Denmark
unfortently not to the PRO propelles  but the props with round hole...   the PRO props has oval holes
2017-9-27
Dobmatt
Flight distance : 1831050 ft
Do nothing, you'll fly just fine. No need to balance genuine DJI props ...
2017-9-27
It seems you purchased wrong propellers, please provide pictures of propeller and propeller mounting plate for further assistance, thanks.
2017-9-27
LarsPlovmann
Denmark
Hmm, no ....  its the normal quick release props = standard on the inspire 1 pro
2017-9-27
Mark Guille
Flight distance : 2031818 ft
Jersey
LarsPlovmann Posted at 2017-9-27 23:35
Hi Lars,
Does the I1 pro have different props to the I1 now?
Mark G.
2017-9-28
Well I think I misunderstood your post, can you please show us the picture of the drone with propellers from the front, we will see if the propellers are normal.
2017-9-28
LarsPlovmann
Denmark
Yes okay...   but there is only one  quick realese kind     but here is pics...
2017-9-28
LarsPlovmann
Denmark
and one more
2017-9-28
I don't see any problems
2017-9-28
LarsPlovmann
Denmark
problem ??    I ask  if someone know  how to ballancing  those kind of Props     I cant find anything fit in to the oval hole in the propel so I can ballanced them...
Do you understand ?
2017-9-28
Mark Guille
Jersey
LarsPlovmann Posted at 2017-9-28 03:54
Do you understand ?
They don't need balancing Lars, if they are genuine DJI props they should be good to go.
Mark G.
2017-9-28
fansa84fe8a4
Amazon has one for the 1550 props which are quick connects and they say for the red and white marked ones.  Don't know if it fits the i1 with the newer QD props but it may.
https://www.amazon.com/EJH-Preci ... ancer+DJI+Inspire+2
Fwiw, I made one out of 10" drill rod and small wooden rectangular blocks (To fit into the props and 90 degrees to each other.) at each end and statically balanced that shaft.  Then pressed it into the I2 props.  A couple were off out of the 8 I have, but not bad overall given their length.  You can rotate them on the shaft 180 degrees and see if they verify if in doubt.  Old RC guys have done that long before DuBro came out with their prop balancer which I also have from the RC planes and use with the above.
2017-9-28
LarsPlovmann
Denmark
No Mark...  they are not ballanced  desend ....  I will still ballanced my props like I always done,  and hope its okay for you
2017-9-28
Mark Guille
Jersey
LarsPlovmann Posted at 2017-9-28 07:04
Fine by me, do what you want matey.
2017-9-28
LarsPlovmann
Denmark
   just Kidding Mark, Hope you can take it
2017-9-28
Mark Guille
Jersey
LarsPlovmann Posted at 2017-9-28 08:33
I can take it Lars Good luck with your ballancering.
Mark G.
2017-9-28
