ro_flyer Posted at 2017-9-27 19:34
I'm very curious if somebody can explain this... because nobody here did and neither does the manual... :-)
as DJi thor has said:
Smooth mode: 720p 60fps; normal mode: 720p 30fps; HD: 1080p 30fps.
basically these are the setting that will stream back to the tablet or phone you use if you set them. however Smooth and HD mode does not allow you to record on the mavic pro in 4K/C4K and 2.7K. because of the extra processing the mavic pro has to do to transmit the extra data to your tablet or phone.
also normal mode gives you the best wireless range since it uses the least bandwidth (can use 10Mhz slice of 2.4Ghz spectrum), smooth mode and HD mode cut the range way down (in most situations) because they have to use more bandwidth (forced to use 20Mhz slice of the 2.4Ghz spectrum)
Thanks to HereForTheBeer answers. The image transmission settings are for choosing the resolution of the transmission stream. And when it is in normal mode, users can record up to 4K resolution, HD up to 2.7K, smooth mode up to 1080p.
Hi people. Do these settings actually work for Matrice 210 RTK with Zenmuse Z30 and Zenmuse XT cameras and CrystalSky monitor? I've switched through every possible setting and saw no difference.
