Problem in transformation modes.
683 6 2017-9-27
djiuser_6SlNYIy
Malaysia
Hi buddys,
I got problem with my Inspire 1 v2 when to transform from landing mode to lock mode (mode for packing into the casing). When transforming to the lock mode, the drone has suddenly transform to flying mode where the landing skid totally up then the bottom of the drone has totally contact the floor. because of that, I need to transform a few times to get the normal locking mode. Any ideas how to troubleshoot the problem?
2017-9-27
Privateer
Flight distance : 117493 ft
My understanding is this can happen if you are on a reflective surface (paint, etc.), or like me when I first got my Inspire I tried to go into travel mode while holding the drone up of the surface instead of following the directions.
2017-9-27
DTK
Flight distance : 1943159 ft
@privateer, you mean the aircraft should be on the ground and flip the landing switch 5 times.
2017-9-27
Please avoiding putting the drone in carpet or grass land that may absorb sound wave. And reflective surface is not suggested.
Please try ground with clear patterns or textures.
2017-9-27
P_Droner
Malaysia
Owhhh...ok, thanks for the answer. I will try it
2017-9-27
P_Droner Posted at 2017-9-27 23:19
Sure, please keep us updated if the problem persists.
2017-9-27
P_Droner
Malaysia
Sure, I will update
2017-9-28
