fans6bd3057e
Flight distance : 1606201 ft
I had most of the same issues with my p4 pro sent the drone back to DJI for repair under the DJI care refresh plan, they offered to replace the drone for 149.00 and I informed them the drone had never crashed and it should be replaced for free,DJI agreed and I should get the replacement drone today and will test it out as soon as tomorrow.
The problem first started with the drone in a remote area with GPS green within line of site of the drone it would go into atti mode and drift with the wind.
Next flight I had the warning that you can only fly a certain distance and height, which in fact would keep me within those restrictions had to land and restart the drone to get it to
work properly. On several flights I would press return to home and the drone would start to return to home then all of a sudden cancel the RTH this happen many times.
At times the drone mapping would quick working in flight I could see the drone was flying forward because the video was working but it would freeze the information at a certain distance
even though the aircraft was moving forward.
The final straw that made me return the drone was the gimbal no longer worked everything would be level then all of a sudden it would jerk around going in all directions, this made the
video unacceptable so I returned the drone for repair or replacement. |
