DronePix
Flight distance : 765469 ft
As far as I understand, a perfectly aligned horizon depending on the hardware and also the software: the gyro need to be perfectly aligned, and then it needed to be calibrated.
A misaligned gyroscope can be "correct" by software, however when it yaw, it will be misaligned again.
To patch the issue up, DJI allows gimbal tilt correction in the Go 4 app. However the tilt will continue when you yaw, and it may compensate itself according to the gimbal tilt correction value you set slowly over a few moment.
Therefore, if the gimbal is tilted dispute calibration, don't waste your time in doing the gimbal tilt correction.
This is just my experience. Please correct me if I am wrong.
