DJI Thor
Flight distance : 13602 ft
Dmitry495 Posted at 2017-12-6 07:54
Thor, I have a question that was actually raised in one of the threads... If you connect Goggles to P4P remote controller without connecting a tablet running GO 4 app, your AC will be subject to height/distance restrictions (30/50m if I remember correctly). However, if a tablet is connected to RC, it occupies USB port on RC and there is no available port to connect Goggles. What's the solution for this case? Thanks
Hi sir, in this case, you can connect the mobile device first, open the app and then switch it back to a set of Goggles, please don't shut down the drone when you switch it. Besides, you can install an HDMI module on the RC, connect the Goggles via the HDMI. Refer to the manual below.
