Flycaster
The other two batteries are fine, charging and flying?
Then, open a case with DJI, and HOPEFULLY, all they want is the suspect battery returned, and you can keep flying.
Where did you buy it? Bestbuy? they might just do a straight across battery only exchange if it is withing the return period. If they don't won't, return the whole kit, and then buy a new kit. See where I'm going with this?
If your purchase point has an easy retrun policy, that is more than likely to happen.
If you bought it at someplace like Frys, well good luck. You will be dealing with DJI warranty support.
And my two cents worth, do not fall into the "Update all the firmware on the Mavic, and controller, and the batteries. all works, just the one battery.
Fly the bird with what came on it out of the box. Learn it, and get a feel for how the bird flies and handles, before you start tweaking updates and such, can open another can of worms. Let other dance with the updates, and wait and see how it goes, then you can decide to run with the "Latest and Greatest" |
