DJI Thor
Flight distance : 13602 ft
Flight distance sometimes relates to the flight environment, we would suggest that you fly the drone in an open wide area. Check the position of the antenna for the remote controller. Distance should be greater than height during flight, and please make sure the remote controller’s antenna is positioned parallel to and are pointed towards the aircraft. Besides, you can also try to rebind the repeater.
