_pk
Poland
DJI Susan Posted at 2017-9-29 23:28
Well received, thank you very much! From the flight records, it seemed that the drone was not landed normally for several times, and we do not suggest to grab the drone as it will be dangerous.
Also, per the email history, the first time you contacted us to report that the motors were obstructed, I do not think it is related with battery directly. If you have more batteries, it will be helpful to verify the issue.
Although I can understand that you do not suggest grabbing the drone, definetely it is still not a crash. If the flight record says that the drone crashed, while it in fact was grabbed in a mid-air, then the flight reccord is simply wrong.
In fact I did grab my drone and rotate it 90 degree to switch off the rotors more than once. I fly mostly in a wilderness over thick foliage where I cannot land the drone normally. I palm-launch the drone to start it but the palm-landing rarely works as it should. I don't know why spark does not recognize my palm and refuses to land but it does. Thus, grabbing it in mid-air seems to be the only option for the time being, and now I read that every time this is reported as a crash?... Weird!
Considering the above comments, I have two suggestions for firmware improvement:
1) If the craft hovers in place and then is rotated 90 degree to shut-down the rotors, then the firmware should recognize the situation and log it as emmergency shut-off of the rotors and not as a minor crash.
2) Improve the palm-landing. Maybe allow the reverse of palm-launch sequence, i.e.: grab the drone and press the power button twice to switch-off rotors (not press twice and hold for complete power-down, just press twice as for palm-launch) and land on a palm.
