Visiting a new country/connecting to the internet?
584 2 2017-9-30
fans417abfbd
Flight distance : 434593 ft
Hopefully this isn’t a stupid question but I guess if you don’t ask then you don’t find out, so here goes.
I live in the UK and shortly I will be traveling to Thailand for several months andI intend taking my P4P+ with me.
Is there something I need to do as far as connecting to the internet when I arrive?
Currently I don’t connect to the internet and I don’t want to upgrade to the latest firmware after successfully downgrading to cure issues that came with the last firmware update.
Thanks in advance for your advice.
2017-9-30
Olivier Vietti-
Flight distance : 11618934 ft
Switzerland
normally this is not necessary, but you must expect that the map displayed silk empty, this does not prevent to fly, check that the time of the silk application the same as the place where you are located so to have a good synchronization with the gps
2017-9-30
fans417abfbd
Olivier Vietti- Posted at 2017-9-30 06:51
Ok thank you. It would be good to have the correct maps though
2017-9-30
