a2 wont work with mini osd
7535 9 2014-9-18
erhank9
Turkey
Hello
İ try to connect a mini osd with a2 controller but wont work.İf i connect to canbus 2 it work but then i have no connection point for the led indicator.if i connect the mini osd to canbus 1 like it should be it wont work.is there any solution for this problem?
2014-9-18
carlton.mcmilla
Flight distance : 5409711 ft
There is a solution. You have not use the Mini and get the full size OSD
2014-9-18
erhank9
Turkey
carlton.mcmilla Posted at 2014-9-18 21:57
Yes that is a solution.İf DJİ says:Miniosd dont work with A2 then no problem
But if the seller says :Yes no problem this mini osd works  with a2 and you dont need the flight log from osd mark2 then why?
2014-9-18
T J Gilbert
Flight distance : 74659 ft
I just checked the product specifications for both items on the DJI website.
The A2 specs don't list the iOSD mini.
The iOSD mini specs don't list the A2.
If you want to give it a go, I guess that you could get the proper CanBus cable to allow connection of the LED and the iOSD mini to the PMU (see photo).
Or you could use the CanBus Hub...
2014-9-18
erhank9
Turkey
T J Gilbert Posted at 2014-9-19 02:37
The A2 specs don't list ...
Yes you are right i couldnt find anything on the dji website about that.But on the dealers websites they say that it fit.However yes i have the cable but its the same like the mini osd cable they wont fit
2014-9-18
erhank9
Turkey
erhank9 Posted at 2014-9-19 04:24
Yes you are right i couldnt find anything on the dji website about that.But on the dealers website ...
Sorry now i see what you mean.İ will try Thanks
2014-9-18
gran-fatto.hotm
erhank9 Posted at 2014-9-19 04:32
Hi erhank9, now your iOSD mini work with A2?
2015-2-1
DJI-Dboy
Hi, Mini is not compatible with A2
2015-2-1
vandman1008.gma
Flight distance : 30997 ft
Just to update those searching for compatibility of A2 and minOSD .
I tested and using miniOSD as its all I need.
Connected to CAN 2 ;
Parts that functions ; Flight modes ( ALT ; GPS ; Failsafe)
                                       Flight pack voltage.
                                       Altitude (Height )
                                       Distance from Home.
                                       Artificial horizon.
Parts that don't work ; Low flight voltage warning ( battery Icon & voltage reading blinks on LW )
                                         Home direction arrow ( points forward )
Pro; Small form-factor ,weight and ease of installation without soldering power lead (to OSD MK2).
Cons; Low voltage warning icon doesn't blink , Home arrow not working. Flight log .
2015-11-15
fansaa32c7f9
Denmark
just for everyone trying to get this "old" hardware to work, you need the Hub to get it working properly.
get at hub and everything works, even the Z15-5dIII works correctly with the hub, no hub and the z15 and mini osd does not work.
2021-10-20
