E1200 PRO quadcopter
1456 9 2017-9-30
ckk.post
Denmark
Quadcopter with E1200 pro
Have plans to build a quadcopter with E1200 pro
where it will lift up to 7kg all in all
Does anyone have experience with these motor
can they do it?
Best
Keller
2017-9-30
Tahoe_Ed
Flight distance : 2605 ft
I have them on a S900.  Based on the specs, Takeoff Weight Max        1700 g/rotor (Sea Level), that should work.
2017-9-30
ckk.post
Denmark
Tahoe_Ed Posted at 2017-9-30 12:50
Thank you
where do you see the specifications
max take off weight 1700 g
can only see recommended  take off weight 1400 g
2017-9-30
DJI-Mark
ckk.post Posted at 2017-9-30 22:37
Thank you
Have you checked the product page for the S 900 copter? You can find that info here: http://www.dji.com/spreading-wings-s900/info#specs
2017-10-2
ckk.post
Denmark
DJI-Mark Posted at 2017-10-2 08:01
Thank
no, I have not found anything there either
since it's not a s900
I will build
but can see the  e1200 pro have  a max trust of 3900g
then it should be possible and lift up to 8 kg at 50% throttle
and because I only need it for photography
and if you can count on the specifications
then should the motors  not become overloaded too much
what do you think
2017-10-2
DJI-Mark
ckk.post Posted at 2017-10-2 10:14
Thank
Take a few test flights with your set up to make sure that everything is functioning as should be.
2017-10-2
ckk.post
Denmark
DJI-Mark Posted at 2017-10-2 11:15
Thanks
I will do that
but what are you thinking in terms of motor power
can it be done
2017-10-2
DJI-Mark
ckk.post Posted at 2017-10-2 11:44
Thanks
I will do that
You would be best to make sure that everything is working up to speed. Hard to say based on hypothetical. Best to test fly it to see in a controlled setting.
2017-10-2
ckk.post
Denmark
DJI-Mark Posted at 2017-10-2 11:54
okay
Will return with answers when I get time maybe this weekend
Best
keller
2017-10-2
ckk.post
Denmark
View full quote
okay
Best
keller
I just forgot and answered here it flies great
They can handle the weight without any problems
2017-11-12
