hyprfrco
Flight distance : 10148 ft
Chile
Mavic Pro Propeller Cage Firmware Failure
This is an alert for Mavic Pro (MP) owners, to not purchase the DJI Propeller Cage.
DJI do not stop dissapointing me in every possible senses and directions.
Yesterday by morning (2017-09-29), having a normal almost absent wind of less than 1km/h, I moved from my Previous Setup onto the New Setup:
PREVIOUS SETUP
- DJI Mavic Pro (2017-05-23),
- DJI Mavic Pro Firmware v01.03.1000 (2017-09-01), (2017-09-01 Installed),
- Aeriatek Propeller Guards for Mavic Pro,
- DJI Go 4, v4.1.8,
- Samsung Galaxy S7.
Having performed some flights at fixed positions for measurement photography with the Previous Setup, I had no issues (2017-09-01).
- Previously, when using the Aeriatek Propeller Guards, with the MC Settings>Advanced Settings> Enclosed Propeller Guards unchecked, i never had an issue. Flying a little dumb, though not so perceptible, obviously because the added mass, but no issue at all. Full control. No complaints.
NEW SETUP
- DJI Mavic Pro Firmware v01.04.0000 (2017-09-19), (2017-09-27 installed),
- DJI Propeller Cage for Mavic Pro,
- FStop Labs Shade Gimbal Cover for Mavic Pro,
- DJI Go 4, v4.1.9 (2017-08-31),
After that, with the New Setup i had the following BUG CRASHES in my last flight (2017-09-29):
- In mid-air, the MP started to (yaw) rotate in multiple instants, at 1 spin/sec aprox. At first i believed i mismoved the controller sticks. After some minutes i realized the issue repeated.
- I though it was some sort of mechanical contact between the Propellers and the Cage, inducing some delay in the spin and causing the overall yaw. But the Propellers Cage Set was just out from the box, and after the flight there were no mechanical irregularity at all.
- I reproduced the error by flying the MP at floor level. This time the MP landed while spinning.
- In mid-air, the DJI Go 4 app, crashes. This never happened with the previous version. After landing the drone, the video was still refreshing from its mid-air shots, with a delay of about 10 seconds.
As its own decision, dancing with itself hilariously. Also in mid-air several times. Do you know how to control a spinning drone which is far from you? Yes. Do it in the simulator with one control fixed at the yaw rotation, and you will see the beauty of the randomness.
I understood the Propeller Cages 180g added mass compared with the 743g with gimbal cover MP total mass, could induce some changes in the dynamics: own turbulence with the same cage walls, slight angle deviations, an additional dumping in the control, while doing changes of directions or under wind perturbances, but introduce random rotations of several TURNS? NO, IMPOSSIBLE.
QUESTION
My question is WHICH WAS THE FAULT?!
WHAT TO DO
What i need now is your instructions|comments|suggestions|recomendations on the following decisions to take on the hardware|software:
- Propeller Cages: Destroy them?, Sell them?, Cutting them on the edges for reducing inner turbulence and reduce mass?, Going back to the AeriaTEK Propeller Guards?,
- Firmware: Staying update at DJI imminent peril?, Go into Factory Setting?, Rolling back?,
- DJI GO 4 App. Download it again? Force the installation of an older version? Drop it to the hell and use an alternative app?, Reduce the Image Transmission Settings into Bandwidth Allocation: 10MHz and Image Transmission Mode: HD Mode for not having a 10 sec delay?
- Change Phone?. NO, i already came from an iPhone 5 (yes! unsupported!) into a Samsung Galaxy 7, just to realize, yes, also unsupported!.
LOGS
Now i will read the tutorials to retrieve the logs and show you the IMU sensors from the last experience, in particular the last one when the MP started to rotate as crazy.
I have all the logs in the phone, but i actually don't know how to get the compass and accelerometer data, for publishing it here.
The PC DJI Assistant 2 app, do not read nor show the logs (thanks DJI, again).
ps. So i would like to compare the IMU data of sensors between both of my setups, for deciding using this drone is a COMPLETE RUSSIAN ROULETTE or WHATEVER OTHER PERIL to find out and discover!.
hyprfrco
