Horizon level shortcut?
1258 6 2017-10-1
Primo_NYC
Hi,
I'm wondering why I can't level the horizon by holding the c1 or c2 button and use the finger dial similar to the way i can on my i1?
It makes it much easier than touching the screen of my ipad. I fly with a Hi-Aerial hood and it's not easy to touch the screen on the fly.
Any shortcut for this would be greatly appreciated.
Thanks
2017-10-1
Irate Retro
You can set it to whatever you like on the 5-direction button.  I believe it's forward by default?  I don't have it memorized because the DJI Goggles interfere with all the buttons so I never get to use it.  I really miss it though.
By the way, how do you level the gimbal with the ipad screen?
2017-10-1
Jyunte
Flight distance : 2103150 ft
Irate Retro Posted at 2017-10-1 20:16
Put your finger on the screen... after a short time, the gimbal display changes and you drag your finger up or down to change the angle. This is the DJI Go all's default action.
2017-10-1
Irate Retro
Jyunte Posted at 2017-10-1 22:05
Hrmmm I vaguely remember getting into that mode.  But if all you're doing in that mode is manually adjusting the angle slightly up or down a little at a time, how is that any different from using the dial?  He's asking about how to "level it", which I take to mean a quick way to get it to exactly 0 degrees.
I mean if you've already got your hands on the controller why would you drag around on the screen.  Sounds like there's a shortcut to 0 degrees somewhere on the app.  That or I'm now totally confused as to why he would even mention it if it's even _more_ cumbersome than using the dial and manually eyeballing 0deg on the meter.
2017-10-1
Primo_NYC
Sorry, I meant to level the horizon, not the tilt of the gimbal.On my i1, I can hold the right c button, after about a full second, the horizon level indicator comes on screen and the right finger wheel adjusts the horizon.
On the MP, I have to go into the app, find the horizon level in the tools and touch the screen to adjust.
I know i can level the horizon in post, but prefer to shoot level, even though it loses the horizon after a couple of fast moves, same as the i1, it makes correcting between shots quicker to use the buttons of the tx.
Thanks for the help.
2017-10-2
EthanCaswell
Flight distance : 13704 ft
I have this issue as well, but it seems to return to normal after a few minute for me. Knowing how to level it back quicker would save those few minutes of flight time though!
2017-10-10
Primo_NYC
EthanCaswell Posted at 2017-10-10 09:12
Turns out to be the same buttons as before, we just don't get any indication on the app.
Hold the right C button and use right scroll wheel together and you can level the horizon.
2017-10-20
