stuka75
Flight distance : 85682 ft
Trees, buildings and anything that will keep you from seeing the ac(LOS) will impede video and control, initiating RTH. Especially trees with leaves. After leave drop here in Wisconsin, penetration gets better, but still will eventually stop both video and control signals. Line of sight also affects signals. Altitude is your friend, up to 400 feet. I fly rural area, and as ac gets farther out distant tree lines will impede signal, unless I raise altitude to bring LOS( Line of signal) back into play . Your SE should get close to a mile I think, but be aware that is with clear line of signal. If your new to flying drone, you should keep in well within visual sight, keeping in mind that is the legal limit in the US. |
