HereForTheBeer
Flight distance : 5381368 ft
i agree, but it isn't a direct reason for mavic to act badly however.. it should act the same with active track enabled at 100% and 20%, the only small difference maybe that it was attempting to return home and glitched out a bit and did not raise itself up..
i suspect he has a similar issue with active track as i have, which is it easily getting confused and loses the subject an drifts around a lot. also if it is like my active track, 100% avoid the road! use it in a field, mine panics and nearly attacked some people walking by as it was following my car...luckily it didn't hit them it instead took up into a parking lot and i have to cancel active track, no effing idea where it was going or what it felt like it was tracking.. in a field its ok, it just stop when it breaks lock..
sidenote to DJi: please update your active track algorithiums, i know im not the only one having these issues where active track sometimes wants to take your head off or gets confused easily, i know more common on the spark, but i think selection of mavic pros and sparks that have a weird bug where they easily get confused and misbehave a little bit, drift aroudn and sometimes cannot track speed properly, specially in bright sunlight.
