PY4CK
Flight distance : 6443990 ft
Brazil
I would like to share one problem I faced over the weekend after updating both DJI GO 4 version 4.1.12 and IOS 11.01 (Beta).
Being a beta tester for the IOS, the update to 11.01 arrived this weeking and I installed both this update and the update on DJI GO 4, version 4.1.12.
I started my Mavic and went to fly as usual. I noticed that by the moment I switched the record button everything went bad. No more audible alarms, no more infomation of height of flight and distance and no information whatsoever of the length of recording. All this followed by an iphone crash, black screen and finally the RTH function to recover the drone that was at this time about 500 meters away.
I tried everyting including erasing completely the DJI GO 4 app and reinstalling the application, but nothing changed. It seems it is associated with the record function.
I tried later with my Mini IPAD with the 4.1.12 version installed and IOS beta 11 (not 11.01) and no problem at all.
So, I do not know if this only affects IOS 11.01 beta or it will afect as well normal IOS 11.1 (non Beta)
My phone is an IPHONE 7 +
I just thought of sharing to avoid this situation with other fellows having the same hardware/firmware.
Other than that, Mavic is a great machine and I am sure that in my case, the next IOS will get it back to normal. In the meantime, I will use the goggles and Mini IPAD.
Have you all safe and responsible flights.
