Zbig
Flight distance : 7349 ft
Poland
Xperia Z3 is a quite thick little beastie. It seems you're out of luck by just a smidgen as DJI states smartphone thickness range of 6.5-8.5 mm for the Spark's controller (https://www.dji.com/spark/info) and Z3 is 8.6 mm thick. Oops. Also, I'm not sure the DJI Go 4 app's layout would render properly on 4.6" screen - hard to tell until you try. Z3 Tablet, on the other hand, seems to be 0.1 mm too thin, according to the specs I found online. I don't think I'd try my luck in Lotto if I were you, mate Also, I'm not sure the tablet would fit there length-wise, although I've seen enough photos proving that it is possible to jam at least some tablets into Spark RC'c holder. For what it's worth, I'm using Spark with my Sony Xperia XZ and I haven't discovered any Sony-specific incompatibilities yet. |
