[POLL] What Remote Controller Mode Do You Use?
123
22811 112 2017-10-2
Genghis9
Flight distance : 961 ft
hdlou94 Posted at 2017-12-19 02:17
I believe whatever you are comfortable with is what you should use..
I'm comfortable with a stick and throttle, but helos/quads don't work that way...sooo, I'm relearning in that respect...
2017-12-19
juicedrummer
Flight distance : 27871 ft
mic75 Posted at 2017-11-11 00:56
I use mode 2 but I’m seriously considering switching to mode 1 because of what I call Xbox syndrome, I’ve been flying for a couple of years now and if I haven’t flown for a while I tend to use the left stick to for forward n back and the right stick for up and down in emergency situations which has led to a couple of minor incidents. After the first incident I was playing on my Xbox when I discovered the stick combination on my Xbox controller was the reason for my muscle memory.
this is why i stick with mode 3.  left stick is always the walk around stick (ie forward/backward and strafe left and right) in almost every FPS or sport game.  right stick was always look around or tilt up/tilt down, look left/look right.  mode 3 feels the most natural to that for me.
2017-12-19
hdlou94
Flight distance : 753163 ft
I think now that this has been brought up, and I just used it the way it was, I might explore..
2017-12-20
Genghis9
hdlou94 Posted at 2017-12-20 02:19
You should
Just keep in mind some pointers that others brought up here
1. Mode 2 is clearly the bomb for most, so anyone used to this and uses your bird setup will immediately be off with your customized or non standard setup.  Meaning you should warn them or reset before handing over the controls
2. Most training sessions are done in Mode 2
3. When teaching someone to fly with your rig and it is non standard ensure you either change it back or warn your students
4. If you ever send it in for repairs etc. ensure you check it before the first flight back as it was likely reset to the default
Enjoy and fly safe
2017-12-20
solentlife
Flight distance : 1087530 ft
Latvia
Something to take note ... may seem unimportant .... but in fact could save you embarrassment.
Generally because of the massive number of RC flyers who use Mode 1 and 2 .... the common error of equating JUST throttle config as the mode is used.
But if you look at the permutations of stick config - you find that throttle is not the only function to identify for correct mode.
I only mention this as I remember an embarrassing incident of a pal of mine in UK ... Another offered him the TX to fly his model. He assumed because of the throttle - that it was a certain usual mode ... he soon found out it was not !! Luckily the model had not left ground before he realised and shut off throttle ...
Of course we all asked him why he didn't  do a ground check of controls ... he answered - model had just flown fine with the guy ... mmmmmmmm well that's something else.
Nigel
2017-12-20
stalker
Flight distance : 13632 ft
Oops. Voted #1 but meant #2.
2017-12-20
Genghis9
solentlife Posted at 2017-12-20 04:14
I wish we could do a ground check too, I do a low level one immediately after takeoff...
2017-12-20
hdlou94
Genghis9 Posted at 2017-12-20 03:28
You should
Ok, you might have just changed my mind  on this whole thing, thank you for the heads up approach,,,
2017-12-20
Genghis9
hdlou94 Posted at 2017-12-20 13:43
Nay don't be swayed...just be informed
Experiment, it's good
2017-12-20
Edward J Smith
Flight distance : 1852408 ft
I use mode 2 because my games on the play station 4 are set that way..................
2017-12-20
Genghis9
Edward J Smith Posted at 2017-12-20 20:10
Interesting you are not the first who has made this distinction, I sense a trend here with gamers...
2017-12-20
solentlife
Latvia
It was joked about with some people I know way back when drones started appearing often ..... "Models for Gamers" !!
Its actually not far from true .. given the different sense of control to a standard RC model. Its even a bit different to a Helicopter ... it has its own system.
Nigel
2017-12-21
Genghis9
solentlife Posted at 2017-12-21 07:44
I would agree with that...I see and feel both a gaming element to it and while I'm not a helo pilot I know enough of their flight ops that these quads really don't follow that line either.
As I have gotten more familiar with my stickology I've notice that I tend to be very jerky at times in applying control pressure/input which at times not only catches me off guard but causes me to come close to a collision.  I need to find my happy middle or sweet spot...
2017-12-21
FatherXmas
Flight distance : 4058619 ft
I use mode 2, never flown anything but drones and all the ones I've flown have been mode 2. I'd probably crash it if I tried to switch now.
2017-12-21
Genghis9
FatherXmas Posted at 2017-12-21 17:27
Then I suggest you stick with mode 2
2017-12-21
Peterx
Flight distance : 1499708 ft
I´d leave the mode 2 on the RC,some times i use a X161 follower X6 and that RC has the mode 2 too.
2017-12-26
Bashy
Flight distance : 2354357 ft
Hey folks, as i mentioned earlier in this thread that i use mode to and occasionally  use the wrong stick, Yesterday was no exception, this time it was the right stick, i was hovering over a field at about 4m and i pushed the stick go up, (heres the rookie mistake) my mate said sommat and i looked at him at the moment i pushed the stick, when i looked back at the screen i saw that i was skimming the earth at 4m high, luckily i was in a field and also was going away from me. normally i am accidentally pushing left stick to go forward instead on up an down...
So,  what should i do, what would you do, swap the sticks round, left stick to turn and go back and forward and right stick up and down and left and right  or is it too late seen as ive used mode 2 for a couple of months now? i could end up in the same boat now i suppose and whos tell if i had set it the other way i would be doing the same blooming thing.
This is my 1st time with RC so........
2017-12-28
thahn4991
I'm so new I'm still trying to figure this out...
2017-12-29
Genghis9
thahn4991 Posted at 2017-12-29 21:36
No prob, take your time and you'll find what works best for you
2017-12-29
Genghis9
Bashy Posted at 2017-12-28 22:29
Well
While I don't have any long time experience with RC flying, I'd consider the following.
Look for consistent trends as you go along and learn.  Nearly everyone is capable of learning and adjusting to these controls, but it takes some time and some can take longer than most.  However, if as you go you are making the same constant mistakes over and over again then that is when I'd consider changing the mode or customizing the layout.  At present you are describing common mistakes that many make and they don't appear to be consistent in nature.
Fly safe fly careful and practice...
2017-12-29
Bashy
Cheers, i will persist for a while longer and see how it goes
2017-12-30
Droner500
I use mode 2 too because all of my beginner beginner drones had that, so now its muscle memory and on that mode I'm able to fly the drone where I want and almost not even think about it.
2018-1-31
RedHotPoker
Flight distance : 165105 ft
Droner500 Posted at 2018-1-31 09:52
Yes Mode 2, is mine too.
But friend, Don't ever stop thinking about it.
Like daydreams can ruin a great flight...
RedHotPoker
RedHotPoker
2018-2-1
RedHotPoker
Genghis9 Posted at 2017-10-2 10:57
Yup muscle memory is a huge factor when trouble is near...but mental memory is a factor too.
I have muscle memory all over my body, for archery, my leather tooling, skating, playing music is where it's key, on a keyboard.  Haha
RedHotPoker
2018-2-1
Genghis9
RedHotPoker Posted at 2018-2-1 12:25
Agreed, it is what makes the difference in a piano virtuoso who can tickle the ivory like no one else...that doesn't happen by just watching what keys you are hitting!
2018-2-1
RedHotPoker
Genghis9 Posted at 2018-2-1 12:27
Nice sentiments, aside from the mention of ivory.
I know you meant no harm, as it's an old saying, when pianos actually had ivory covered keys.
RedHotPoker
2018-2-1
Genghis9
RedHotPoker Posted at 2018-2-1 12:36
[view_image]
You mean they don't anymore
2018-2-1
RedHotPoker
Genghis9 Posted at 2018-2-1 12:42
No. It's now a plastic material.
Besides ivory dries up, shrinks and even changes color over the years.
But it looks nice. To start out.
RedHotPoker
2018-2-1
Droner500
RedHotPoker Posted at 2018-2-1 10:27
I don't literally stop thinking about it, what I meant is that I don't have to look down at the controls and study my drones position and which toggle switches to press to move where I want to go.
2018-2-8
Genghis9
Droner500 Posted at 2018-2-8 11:05
Absolutely, I get it...
That is what muscle memory is all about, thanks for your input
2018-2-8
RedHotPoker
I don't know anyone who has to look down at the RC to figure out which way to push a stick.
It becomes second nature.
RedHotPoker
2018-2-8
fanse397465a
Flight distance : 23136 ft
I use mode 2 traditional mode for U.S. base Radio Control pilot. HOWEVER back in the old day we use to fly mode 4 with ailerons and rudder (yaw) switched to allow better precision acrobatics
2018-3-3
Genghis9
fanse397465a Posted at 2018-3-3 05:28
I can appreciate that, I'm a stick and rudder guy and find these setups still a bit confusing at times.
2018-3-3
123
