Dirk52
Flight distance : 232995 ft
HereForTheBeer Posted at 2017-10-3 10:56
ya its a stupid non sense feature iOS 11 has, makes me a little angry.. makes no sense and feels misleading to have that toggle there. i cannot find a single use case where i would want to only disconnect from all connected BT devices but not turn off BT.. why leave BT on and draining battery and doing nothing for you...what is the point? other issue i have with BT is it is a privacy risk, i disable BT when i travel because i learned advertisers and hackers love to track people by BT since it is short ranged they can know more or less an exact indoor position depending on beacon placements. dumb move by apple i hope they change it back to an on off toggle not a pointless disconnect button... bit like having a wifi toggle that doesnt turn off wifi just disconnects you.. pointless..
as for ios 11 + 4.1.12, for me and my iPad mini 2 the lag has disappeared, still occasional hiccups, that probably related to ios 11's new handling of certain things i'm guessing, but it should get better with updates.
You read the link I posted?
For me it is the right and perfect solution.
There are several situations I want to disconnect from a WiFi or Bluetooth device but keep my watch, AirPods, pencil, handoff, AirDrop and so on active. If you use more than only an iPhone it is a very intelligent solution. |
