Inconsistent warning and update fails with latest firmware
1560 23 2017-10-3
H4RDCORE
Hungary
Hello everyone,
I'm seeking help because at the weekend I upgraded my Mavic to v1.04.0000 and then DJI GO said there is some inconsistency and upgrade. The upgrade failed with the batteries (I have two). Then I tried it with assistant, also failed giving me a 0x020102 error undefined. I tried to refresh my firmware, that failed either at 40%. I tried everything I could the Mavic works I think although I didn't wanted to fly because of the inconsistency warning. I tried to format the sd card, try another, do the upgrade on other PC and other phone. None of them worked.
Please, help me!
2017-10-3
DJI Susan
Just to verify, does the same error code appear in the two batteries? Could you upload a screenshot of this? I'd like to look into it.
2017-10-4
H4RDCORE
Hungary
DJI Susan Posted at 2017-10-4 02:01
Yes the error is the same with both batteries. Now I'm at work, so I can not try it again and post a screenshot. Sorry .
2017-10-4
H4RDCORE
Hungary
The inconsistent update starts at 31 percent, goes to 49 then back to 46, again 49, then it jumps to 94 and in time it fails. This is with DJI GO, but with assistant its almost the same. Goes back from 40ish percent then jumps to 94 and then fails.
Thank you for your help!
2017-10-4
Anthony566
Flight distance : 2488944 ft
H4RDCORE Posted at 2017-10-4 02:17
Have you tried updating via the lower usb port on the controller ?
2017-10-4
H4RDCORE
Hungary
Anthony566 Posted at 2017-10-4 04:07
Thank you for your reply Anthony566, you mean when I plug the phone there? I have not tried it yet, but if you suggest that I should do, I will try!
2017-10-4
H4RDCORE
Hungary
It doesn't work. I did a succesful refresh from DJI GO, but still can not update inconsistency it fails and I couldnt downgrade to previous firmware.
2017-10-4
DJI Thor
Flight distance : 13602 ft
H4RDCORE Posted at 2017-10-4 11:25
Could you please provide me with your DJI email account? I would like to forward a beta for you to update first for this issue.
2017-10-5
fansac027f5e
Flight distance : 384567 ft
Russia
Tip: The post by the administrator or moderators shield
2017-10-5
fansac027f5e
Russia
dji why are you ignoring me, all have helped. I have a shoot Sunday and mavic does not work!!!!!!!!!
2017-10-5
H4RDCORE
Hungary
Could someone provide me the beta through email, because I still didn't received it. Thank you!
2017-10-6
FLflyer
Flight distance : 79642 ft
I also have had a host of issues with recent updates and version consistency checks.  After I thought everything was OK and had several non-event flights, including one this morning, I had a total out-of-control flight and crash...totaled the bird.
2017-10-6
H4RDCORE
Hungary
FLflyer Posted at 2017-10-6 13:28
Uh, damn, sorry . What happened?
2017-10-6
FLflyer
H4RDCORE Posted at 2017-10-6 14:20
https://forum.dji.com/thread-115613-1-1.html
2017-10-7
DJI Susan
fansac027f5e Posted at 2017-10-5 05:47
I also have similar problems please help
Sir, I have replied you in this post: https://forum.dji.com/thread-112487-2-1.html. You have been added in, please try to upgrade again.
2017-10-8
DJI Susan
Sorry for the late response. We have added you in the list, please refer the below and try again.
1.Log into your DJI account.
2.Upgrade the firmware V1.3.8.10 or V1.3.8.11. or V1.3.8.13
3.Once it's done, please press the "Record" button on RC and make sure it's recording, then start to upgrade firmware to the latest one, it will be working.
2017-10-8
H4RDCORE
Hungary
Thank you Susan, I really appreciate it, I will reply if that solved my problem. Thank you again!
2017-10-8
DJI Thor
fansac027f5e Posted at 2017-10-5 22:16
Sorry for the late reply, we had replied you on another thread, please check.
2017-10-8
H4RDCORE
Hungary
Dear Susan and Thor,
I tried to update to the latest v01.04.0000 firmware but it failed via Assistant and DJI GO, but I tried also the v1. 03.1000 (I think) and it's a success! So I would like to ask could you make that firmware accessable for me at all times, because the latest is buggy for me. Thank you for your help!
2017-10-8
DJI Susan
H4RDCORE Posted at 2017-10-8 12:04
Could you be more specific of the new firmware issue? I'd like to look into the exact status.
2017-10-9
H4RDCORE
Hungary
It fails just like before with the same error code, but the previous one installed successfully.
2017-10-9
DJI Susan
H4RDCORE Posted at 2017-10-9 04:03
Do you follow the instructions in 17#? Every step is important to follow. If still no helps, please contact the support and send it in for diagnosis: http://www.dji.com/support.
2017-10-10
H4RDCORE
Hungary
DJI Susan Posted at 2017-10-10 22:50
Of course I did, I only could downgrade the firmware with these instructions. I do not want to send it in, because it is obvious now, this drone doesn't like the latest firmware, that's all. It was good with the previous one and I started having problems after the upgrade, there was nothing before. It is simply a bug in the latest firmware which is not fully compatible with my bird. I uploaded the error log every time, I hope DJI engineers could fix this for me. If I wouldn't be able to upgrade to the next firmware I will send it in, but this is nonsense because I only have the drone like 2 months.
2017-10-10
DJI Susan
H4RDCORE Posted at 2017-10-10 23:47
I do not think the issue was caused by the firmware directly. In order to get the exact status, I still recommend you to send it in for a fully check as the previous suggestion works on most drones.
2017-10-11
