djiuser_Kf4iPA3
Flight distance : 510968 ft
Israel
mtnlandpix Posted at 2017-10-4 10:46
Based on my experience as an Amateur Radio Operator for many years: 2.4 Ghz will transmit data farther than 5.8 Ghz due to the lower frequency and longer wavelength. 5.8 Ghz will however transmit data at faster speeds, possibly reducing latency. 5.8 Ghz though, due to shorter wavelength will be more prone to interference from solid objects such as trees, tree leaves, and even raindrops. One of the issues with 2.4 Ghz is that so many devices use this frequency creating increased possibility of interference. (I.E. garage door openers, microwave ovens, etc.) Also factoring into the equation is the differences in the government maximum transmission power regulations for each band as Galchanto shows in the Spark Secs chart above. (FCC vs. CE, etc.)
That's my 2 cents worth.
Nice summary.
Just a few additions:
1. the effect of trees and tree leaves is not necessarily bigger when wavelength gets shorter. when it comes to tree leaves in particular, it depends a lot on the ratio between the length of the leaves and the wavelength. That is even more true with conifer trees, such as pines - those needles act like little antennas absorbing signals at certain frequencies, depending on their lengths.
2. Keep in mind that the offered bandwidth in 5.8 is bigger. The spectrum DJI supports in 5.8 is 80MHz wide, as opposed to 50MHz in 2.4 .
Still, I agree that statistically speaking in an open environment with few other sources of RF interference - 2.4 should perform better in most places. In en environment more dense with other RF users - it's not so clear. |
