lightbridge ground unit power plug
2435 11 2015-4-7
mark97564
Flight distance : 2067749 ft
Where can i get the power plug for lightbridge's ground unit? I been using a 35ah 12 volt agm battery to power my dc to ac inverter so i can use lightbridge's ac charger in the field but its getting old.  I just need to know what it is and how to get it so i can use a 4 cell Lipo to charge and run it..
Thanks
Mark
2015-4-7
smee56
Flight distance : 18655 ft
Good luck, you now join the long list of people trying to find the answer. Just like many people have, I have searched all the component suppliers and have not been able to find a suitable replacement. In the end i brought another charger and cut the cord. Less than ideal....Yes....but it works.
2015-4-8
mark97564
Im thinking about cutting my cord and putting a xt60 connector on it so i can simply plug it back together or to another battery..  im pretty sure i seen a dell laptop within the past few yrs that used the type of plug lightbridge uses but i dont know how to look into that..  maybe you could in a spare moment...
2015-4-9
kleake1
Flight distance : 1361040 ft
I ended up cutting my cord to adapt it to a mobile charger.  Less than ideal, but it would be MUCH better if DJI would allow us to purchase an adapter and power it with something else as it shows in the instructions.  Nice to advertise a feature that is never available.  False marketing?
2015-4-9
mark97564
Digikey has a regular type barrel plug in the size of:  6.5mm o.d. and 4.3mm i.d. and another size of:  6.5mm o.d and 3.5mm i.d.  will one of those work on the lightbridge ground units power plug?  If not what size would it be?
2015-4-10
mark97564
Dji? Please answer..  would appreciate it. .
2015-4-12
mark97564
Dji, are you out there?  Need help finding a power plug for lightbridge's ground unit please.
2015-4-14
DJI-Autumn
Hi Mark,
We have two different kinds of power plugs for Ground Unit. Is it replaceable ?
2015-4-15
mark97564
Are you asking me if its replaceable? If so i am sure it is if you can tell me what plug will work with it. I am trying to find what power plug fits the lightbridge ground unit.  I dont want to cut my chargers cord to be able to run it off a external battery.  I need to know dimensions or specifications of the power plug. Or at least a link to one that will work..
2015-4-18
mark97564
Hello.. is dji out there?
2015-4-22
LBRO
While on Groundstation cabling, would it be possible to add a Spektrum TX as a camera radio alongside my exsisting Pilot radio which is Futaba.
I realise mapping is required but cannot find any  technical reference from DJI stating YES or NO.
Both Txs will be using the trainer ports and RF off. with DJI supplied cables.
2015-5-11
mark97564
Yea. U don't need matching transmitters..  just set them up in lightbridge's pc app and your golden. U just need to use the y cable that came with lightbridge
2015-5-13
