QuadKid
Flight distance : 482349 ft
Just so I understand you correctly you D/Graded the FW to 01.03.1 > tested it using that FW version and everything worked OK correct?
If so have you tried to update to 01.04.0 again? If so did it work correctly on the 2nd update attempt?
I am running 01.04.0 and the only time I get that warning is when the AC is on the ground or below 2 meters as the downward sensor is activated, once above a couple of meters the IFM's work OK. |
