Micato
Flight distance : 2057103 ft
Croatia
Hi, first to say after troubleshooting with DJI they suggested to send them my RC for repair. I have some work before winter, so I declined for now. I am using Ipad mini 2 mostly with OTG.
I still belive that my problems are software based.
1. Limitation distance 50 meter and altitude 30 meter --- it occurs every 3-5 flights, I have to land logoff from the Go4 app and logon again, annoying and you never know when it will happen again. When you are done with this process battery is at 70% if you first tested limitation first(flown 50m from me or 30m up).
2. OTG, Every time when I shut off RC and AC and power it up again--- I have to plug out Micro USB and plug it in again to see app picture and statistics, why is that??
3. When using OTG cable RC does not save settings for "Fn" function buttons. When connected via wi-fi it does.
4. My RC does not beep at 30% battery, set by default. RC speaker beeps when starting and shuting down and RTH, so I know that speaker is working.
5. Inside in ATTi (no gps) mode max. altitude is 4m (wi-fi&OTG).
6. When inside using "tripoid" mode every few seconds app says "ATTi" and then drops from "tripoid mode" to ATTi, let say normal speed, not super slow like tripoid.
I have lot of experience with S1000, Inspire1 and now some with this wonderfull little thing, but bugs are here.
Do you masters of the Sparks think that may issues will be solved in the next firmware update or should I send my RC for repairs? THANK YOU !
