Turbotorte
Flight distance : 9885 ft
DJI Thor Posted at 2017-10-5 00:39
Hi Turbotorte, I am sorry to tell Nvidia Shield K1 is not on the support list, so I can't have more info about this device, hope other pilots who use this device will help to give the answers.
For your Samsung Note 8, only for the connecting issue with the RC, I would suggest that you can try to use your original USB cable and plug it into the bottom's port. Note that you need to unplug the side cable first. But unfortunately, this device is not on the support list, too, but it doesn't mean that the DJI GO 4 will not compatible with it. Give it a try if you want.
I did try that too, impossible to fit right because of the USB type c plug being almost out of the sliders path. Also the Screen protection I use will lift up.
I just hope that the Problem with the Shield K1 is fixed because I did not hear anything about that problem for a while now. All the downgrade to android 6.0 threads, videos, and co are almost 1 year old and the latest I found was back in May.
The App works completely fine on my second old phone Xperia X using 7.1.1. This gives me a little bit of hope that the K1 will work now on 7.0.
I hope that some Pilots using the K1 will give me some information about it
Thor I wrote you an PM.
Greetings! |
