hallmark007
Flight distance : 9827923 ft
Really airdata logs are not that good you could upload to http://www.phantomhelp.com/LogViewer/Upload/
However looking at log it shows you had compass warning at 8ft a few seconds in to your flight. That was the time to land and check your aircraft.
You continued on with a lot of compass interference it doesn’t show in your log how long you were flying Atti mode but I suspect most of it although you may have taught you had control of AC you most likely didn’t, you eventually lost Radio signal for 4.6 seconds which triggered RTH . In your log it shows gps was connected during whole flight I’m not so sure, phantomhelp logs would show this better. You must have had gps when you lost signal otherwise it would not have RTH.
I think you were lucky which is good. I would like to know if you calibrated compass lately and where also your take off was there any concrete with metal or other metal objects that might have interfered with your compass.
Was it your fault, I wouldn’t like to say as there have been a number of similar incidents on the forum lately, we would need to see more info, hopefully you can put it down to experience.
Good luck. |
