jcgoobee
Flight distance : 476119 ft
hallmark007 Posted at 2017-10-5 09:34
Wind warnings are set a bit soft on dji aircraft, usually when you fly over 7 m/s they will pop up , just be careful unless you are in a wind that’s moving aircraft around while you have good gps you should be ok . Also by reducing your altitude wind will be lighter.
Hi hallmark007, thank you, but the thing is, if I don't have a visual of the craft anymore, due to high attitude, it's hard to gauge if the wind is actually moving the craft around erratically. I supposed that I can rely on the video feed from the phone but not sure if there's a better way to do this. |
