Ismar 1
Flight distance : 2349 ft
Brazil
I need help so that the radio control does not connect to the dji go application, could you help me?
Personally, I'm Ismar I live in Brazil and I'm using google translator, I hope you can help me, I can not connect my smartphone to the radio control of the phantom. the DJ application does not match the radio or my phantom model, making it impossible to connect to view the video.
Until then my equipment was normal after updating the firmware tested and it worked normally so I turned it off and put it to load, when reconnecting it no longer connected.
I already changed the usb cables and put other smartphone devices and still the problem continues.
I use the Android 7.1.1 system, I already activated the developer option, the debug usb and did not solve the problem.
Is there any way to reset the whole system back to zero? or to correct this problem? follow the data on my device.
FCC Aircraft ID: 553-WM3221510
RADIO: SS3-GL3001510
DJI GO: v3.1.11 |
