hello, i cannot activate the agrass mg-1s RTK, it's stuck at Step Two when you name the drone and Mode... it says Code Error 1008... what;s the meaning? can someone help me?
Are you trying to activate the aircraft through the App? Are you linking your mobile device to a Wi Fi modem? Can you provide a screen shot?
Here is a link to the Quick Start guide: https://dl.djicdn.com/downloads/ ... t_Guide_v1.0_EN.pdf
Generally, the error code 1008 means that the Main Control did not detect the aircraft serial number properly, please make sure the aircraft serial number has been input in the dealer system correctly and try again.
DJI Susan Posted at 2017-10-16 02:13
properly, please make sure the aircraft serial number has been input correctly and try again.
hello
sorry for late reply, where can i input the serial number?
It is one step of the dealer system. Please contact your dealer and make sure the aircraft serial number has been input correctly. Then you can try to activate at your end again. Please let us know if there is any further questions.
