Go app overlapping buttons
512 5 2017-10-6
dvirb
Israel
Hi guys!
I have this strange problem with the go app when flying the mavic with Samsung Galaxy s7
As you can see in the pictures below,all of the buttons got meesed up and moved to the right side of the screen overlapping each other. It makes it really hard to push the right button. Does any one has any idea how to fix it. I tried to uninstal the app, played with the settings of both the app and the phone with no success.
Thanks!
2017-10-6
dvirb
Israel
lannes
Flight distance : 4465 ft
is it something to do with screen resolution
2017-10-6
STST
Flight distance : 734882 ft
Israel
Change the phone language to English,
Yo may usage language that warting from right to left
2017-10-7
Ismar 1
Flight distance : 2349 ft
Brazil
I need help so that the radio control does not connect to the dji go application, could you help me?
Personally, I'm Ismar I live in Brazil and I'm using google translator, I hope you can help me, I can not connect my smartphone to the radio control of the phantom. the DJ application does not match the radio or my phantom model, making it impossible to connect to view the video.
Until then my equipment was normal after updating the firmware tested and it worked normally so I turned it off and put it to load, when reconnecting it no longer connected.
I already changed the usb cables and put other smartphone devices and still the problem continues.
I use the Android 7.1.1 system, I already activated the developer option, the debug usb and did not solve the problem.
Is there any way to reset the whole system back to zero? or to correct this problem? follow the data on my device.
FCC Aircraft ID: 553-WM3221510
RADIO: SS3-GL3001510
DJI GO: v3.1.11
2017-10-7
DJI Thor
Flight distance : 13602 ft
How about changing the mobile device system language to English? Our engineers are aware of this case and working on it. For now, we would recommend changing to English.
2017-10-7
