Inspire1 V1 landing gear stuck
16753 27 2017-10-6
fans9037f8fe
Flight distance : 246250 ft
Cyprus
Hi all,
After my last successful flight, my inspire 1 was packed for 3 months. Decided a few days ago to take it out of its case and update it to the latest version. However, it wouldnt come out of travel mode, no matter how many times I tried.
So, I decided to carry on with the update exiting ofcourse from travel mode (the landing gear remained stuck but the blue led was off) . I attached the camera by putting the bird in bettween 2 chairs. The update was successful and the I updated the RC. Again, communication bettween bird and RC was ok but the landing gear remeined stuck....
After searching the forum and reading similar problems and advises, I tried to move it manually with a screwdriver. The landing gear then moved to all positions very smoothly but wouldnt do so via RC.
I packed it again, and today I decided to try again without any success... Then I tried the screwdriver method but wasnt moving and was really stuck like the screw was glued... After powering it a few times on and off, the screw then unstuck and was able to manually move the gear, but no way being able to move via RC. Note that every time I was trying to move the gear via RC either by the software or by the RC button I could hear the servo on the inspire working and the led light exiting blue or entering as it should be.
Any help guys?
Thanks in advance,
Alex
2017-10-6
DJI-Jamie
Flight distance : 112405 ft
Just to clarify, was this happening before updating anything or was it after updating the RC first?
2017-10-6
Aeromirage
Flight distance : 1778045 ft
Sounds like the bearing at the bottom of the worm drive is stuck. Maybe rusted or full of sand /dirt.
Also check to make sure LG motor is plugged in.
2017-10-6
AlexisCY
Cyprus
This happened before the update. After my last successful flight packed it for a couple of months  then I decided to update and it wouldn’t come out of  travel mode.
As for the cables I have checked them and they seem to be ok. I would agree with the sand/dirt or rust but since it turns fine with the screwdriver i don’t think that’s the problem.
2017-10-6
Donnie *
Flight distance : 3636782 ft
You were on a smooth level surface when trying to put the Aircraft into travel mode correct ?  does the gear work normally when raising or lowering the gear for flight .  If it does you can more than likely eliminate the servo or the gear as a source of the problem .  But if the Gear does not go smoothly up or down then thats the problem.
*** I f you were trying to get travel mode OUT between the chairs that wont work.  MUST be on HARD LEVEL SURFACE, a hardwood floor works best in my opinion.
donnie
2017-10-7
Tmygun
Flight distance : 2972497 ft
AlexisCY Posted at 2017-10-6 23:49
Donnie is correct......if you try to do it on, lets say, a carpet or grass,  the sensors on the bottom of the inspire will get confused and not engage/get out of travel mode.
It must be on a hard smooth surface to activate/de-activate travel mode.
2017-10-7
AlexisCY
Cyprus
Yes all of my attempts were on a hard level surface
I can hear the servo working/making a noise  every time i try to lower or raise the legs without any movement on the main screw. Should I take out the servo and check if the gear turns when I give the  command ? I will also make a short video maybe someone with more experience than me could tell from the noise
2017-10-7
Donnie *
AlexisCY Posted at 2017-10-7 08:33
So will it raise and lower in flight normally ?
Does the AC work otherwsie ?  You can start the motors and fly if you wanted to??  Granted with the gear stuck down I woul assume . This is improtant to know .
donnie
If NO then the Servo more than likely has failed, Inspect the mesh of the gear by lifting the boot and see if there are pieces of the gear or if the mesh is to tight , add a drop of lube if you can then work it in by manually working the gear up and down.
Proper way to lower and raise  manually here :
Instructions on How to:  Landing Gear Manual Raising and Lowering.
donnie
2017-10-8
simonm
Flight distance : 406886 ft
Alex, I have a similar problem with my I1.
Everything was fine when I last used it a couple of months' ago but the landing gear just isn't responding now. I can hear the motor turning when I try to go in/out of travel mode but the legs don't move. They move easily when I use a screwdriver to turn the worm gear manually so nothing is seized.
Just wondering if you ever got to the bottom of this problem with your Inspire as it seems I may have to replace the center frame assembly which is fairly expensive.
Thanks,
Simon M
2017-11-14
TruGreen
Flight distance : 621909 ft
simonm Posted at 2017-11-14 06:24
fairly Expensive and not easy to change. literally EVERYTHING is built on and around it
2017-11-14
Videophotog
Flight distance : 4313976 ft
Ever get this fixed?
2018-5-10
kefirmarket
Flight distance : 134357 ft
Turkey
any news ?
I have the same problem. After 4 months not flying LG is not moving.
I hear the sound of the LG motor, but it s not turning the big shaft.
As I saw on youtube the motor is working but the gear on the motors shaft is loose.
So is a repair possible? Fixing the gear to the motor?
2018-8-7
fans20fd8cdb
Flight distance : 57566 ft
Saint Lucia
I have the exact same issue. Any solutions yet?
2019-1-11
fansecae48f4
Flight distance : 162785 ft
Costa Rica
Any update on this? I have the same issue after not using my inspire 1 for some months
2019-4-19
fans4921f63c
Same issue. Any solutions?
2019-4-27
fans4921f63c
2019-4-27
OleBrown55
Flight distance : 340397 ft
Same problem with my Inspire 1.  Now 'fixed'.  I took apart the aircraft so that I could get to the landing gear retract motor and shaft for inspection.  I too found that the tiny brass gear that is supposed to be fixed to the gear shaft was spinning freely.  These parts are too small for me to make a key way, or even a set screw.  After consideration, decided to use use JB Weld.  I first roughed up the shaft using a Dremel grinder and a small drill bit for the inside of the gear.  This shaft is 1.6 MM diameter, so not many options.  I then cleaned the surface with Acetone.  Using a tooth pick, I carefully mixed and applied the epoxy to the shaft, set the gear on it and allowed it to fully cure.  After reassembly, testing and flying, no issues.  I get no guaranties, so I found and ordered a "DJI Inspire 1 Part 2 -Middle/Center Frame Component Assembly For DJI Drone Inspire 1 /1 V2.0 /1 Pro".  I have now received the DJI replacement part, pictured below, and can implement if my epoxy job fails.
Inspire 1 Landing Gear Motor gear
2019-5-6
Norb_T
Flight distance : 299593 ft
OleBrown55 Posted at 5-6 04:09
Same problem with my Inspire 1.  Now 'fixed'.  I took apart the aircraft so that I could get to the landing gear retract motor and shaft for inspection.  I too found that the tiny brass gear that is supposed to be fixed to the gear shaft was spinning freely.  These parts are too small for me to make a key way, or even a set screw.  After consideration, decided to use use JB Weld.  I first roughed up the shaft using a Dremel grinder and a small drill bit for the inside of the gear.  This shaft is 1.6 MM diameter, so not many options.  I then cleaned the surface with Acetone.  Using a tooth pick, I carefully mixed and applied the epoxy to the shaft, set the gear on it and allowed it to fully cure.  After reassembly, testing and flying, no issues.  I get no guaranties, so I found and ordered a "DJI Inspire 1 Part 2 -Middle/Center Frame Component Assembly For DJI Drone Inspire 1 /1 V2.0 /1 Pro".  I have not seen this yet, may never need it, but it should have the components included, if my epoxy job fails.
Thanks for posting this.  I believe I have a similar issue as the landing gear will not retract for travel or flight.
2019-5-6
OleBrown55
Norb_T Posted at 5-6 14:41
You are welcome, apparently it is a rather common problem.  I think that moving forward, if I don't fly mine for an extended period, I may manually get it started by turning drive shaft with a screwdriver to ease the tendency for it to get stuck in a locked condition.
2019-5-7
Jessandted
Flight distance : 390 ft
Hi, did repair hold? Just happened to mine that’s always kept in case in dry summerhouse and gear lays raised on case (plastic low resistance) did you get gear from Aliexpress or dji? Regards, Alex
2019-6-30
Jessandted
Hi, did repair hold? Just happened to mine that’s always kept in case in dry summerhouse and gear lays raised on case (plastic low resistance)  Regards, Alex
2019-6-30
djiuser_AZPosvBJa1Og
I'm having the same problem with my inspire 1.
After a month sitting the landing gear won't go up or down.
I have lubed it, manually moved it up and down and cleaned and checked all the connections but still not working.
Does anyone know the voltage of the landing gear motor?
I would like to hook it up to a battery to see if the motor is burned out.
Any advice would be greatly appreciated.
2020-9-12
StewEdwards
Another person with the same issue.
Took the DJI Inspire 1 out after  long break, it was stored in the travel mode
Gear travelled down and flew fine but gear would not raise so continued flying with gear down, no problem.
Manually retracted gear with screwdriver, all smooth and left gear in the up position with gear selected up on the controller.
Powered up craft and gear travelled down smoothly without any selection being made, will not travel up although motor runs and green Landing Gear Up message on controller.
Anybody know what is going on here, it will travel down but remains down when selected up.
Kind regards
2021-5-31
djiuser_ewkGuFbA992a
Flight distance : 72110 ft
Suriname
Hi i have a inspire 1 and the landing gear does not react automaticly. I have to give it a push or turn it a bit with a srewdriver. Can ony body tell me what the problem is.
2021-7-7
Suriname
Hi i have a inspire 1 and the landing gear does not react automaticly. I have to give it a push or turn it a bit with a srewdriver. Can ony body tell me what the problem is. .
2021-7-7
fanscff2105d
Hi, My landing gear is also faulty. Greased regularly behind the gator. Removed servo and the tiny brass toothed cog is free spinning on shaft of motor. Ive applied glue as best I can and awaiting testing. Can I buy just the servo head? which includes the electronics etc, I don't want to buy the whole frame assy as mine is fine, oiled and no dirt.
Thanks
2021-8-4
Codywilson76
Ugh.  Had mine stored in a sealed pelican case for a few years while I had kids, got a new job, and moved twice.  Got some drone work- took her out for a spin after a quick firmware update and the gear wouldn't come down.  After a very stressful landing in the grass, on top of my camera I can hear the motor turning but I suspect I have the same problem as everyone else- the drive gear is slipping on the shaft. I used the manual standard screwdriver trick to lower the gear- man was it tight! I could hear the gear train spinning as i turned the screwdriver.
Then I tried it with the drone on and same result- spinning motor and no movement.
Edit- found a video on fixing the brass drive gear on the servo motor. Not excited about tearing this thing down.
2022-3-28
fansc8b60871
Codywilson76 Posted at 3-28 17:26
Do you where I can also find that video?
2022-7-12
