birddawgg
I know its nearly impossible as most turn turtle when you loose power and the pitch of the props are fixed but.........Today my Spark auto rotated from 500 feet. How is this possible you ask? You have to meet two very important criteria.
1st - you have to have a forward CG
2nd - you must be facing into the wind
How did I attain these two critically important factors? I can tell you that it is a nearly impossible feat but what you need is for your battery to eject itself after nine minutes of flight. This event satisfies the CG condition needed for the proper forward speed from a dead hover. Secondly you must be lucky enough to be facing into the wind.
Having said all this you may have guessed that this was not a controlled decent. The left side of the battery retention system failed which I still wouldn't think would cause the battery to eject from the Spark but it did. With no prior warning I lost signal and immediately heard the blades speed up. My initial thought was that it was returning to home, so I looked up to watch it decend and land. Well as I did so the first thing I saw was the battery whip past my head and bounce in the parking lot. Signal loss explained, the spark blades were still screaming and I watched it make a shallow arc from over head to six or seven spots over and bounce across the lot as well.
Spark status, battery = toast. The Spark itself has some road rash on the bottom and I had to snap the top right corner of the top plate back into position. Did a flight test and it flys perfect (for now) video quality excellent, gimble good, gps system good, l.e.d.s good and blink appropriately, responds to all commands, blades good and locked into position.
A+ for crash survivability.......F for battery retention
