Kloo Gee
Flight distance : 16783757 ft
Andrew,
If your goal is to take video and pictures with your Spark, then you really need to insert a MicroSD card into your Spark and use the video footage recorded directly from there. The footage on the SD card is recorded in 1080p where the cached version is at a max of 720p. Also, the cached version is subject to any hiccups in the transmission signal between your Spark and the controlling device, whereas the video recorded on the SD card is the pristine original footage.
Having said that, the footage you posted is reading up pretty bad. How far away and how high was your Spark? Also, was there anything between you and the Spark? Are you using the remote control or a direct WiFi connection from your phone/tablet? |
