DazzauksDad
Flight distance : 124446 ft
Odyseas Posted at 2017-10-10 22:42
Hi Susan,thanks for the reply. On android the RC update keeps fails , I am on 1.6 (doesn't let me update to 1.8) and the aircraft had the latest so I downgrade to factory version without success.I will try with a iPad mini 2 , can you please let me know a version for both aircraft and RC that cooperates?
Ok bit the bullet and upgraded my P4 and RC doing exactly as my son did I got the two notifications when updating the p4 saying something about not compatible just pressed ok and it carried on till it said complete...calibrated IMU
went and test flew it 100% perfect steady as a rock
I followed this guide by my son..
[ The way I did it is probably different for what a lot of people say, but I’ve always updated my phantoms this way.
I plugged in my iPad and turned controller and iPad on. With no drone turned on.
I then updated the firmware on the controller and restarted it. Easy.
Then I turned iPad , controller and drone on and clicked the update firmware button on the go4 app home screen.
This told me to connect the device via the lead supplied. So I left everything turned on unplugged the usb from the rear of the controller and plugged it into the adapter lead and then the phantom. Then I thought I should turn everything off and back on. So I did.
Once all fired back up I pressed the update firmware button it started doing its thing.
I had 3 weird tings happen. But kept going and it said successfull.
1st and 2nd was a error message at around 94% it said something like this device is not compatible with the update. I clicked ok and it continued through to 95% then at 96% same error again I clicked on again and it continued to 97%.
Then at 97% the camera started going crazy up down left right side to side hard as well thought it was gonna snap but I had to let it go until it reaches 100% said successful or whatever and then turned everything off quick lol.
Fired it all up again and this time it said there was a geo fencing update. Did this in like 5 seconds restarted it all again and took it outside for a very quick test.]
since both of us updated been for a couple of flights using three batteries each the last day there was no wind at all both p4 hovered absolutely still and performed perfect even tested out the new enhanced option tripod mode and all other modes sport atti no issues at all both aircraft were purchased at the same place and time late April this year
Ricky
