Cetacean
Flight distance : 2528264 ft
Aloha wataero,
The setting is called Yaw Endpoint and has a sensitivity from 60-300. If you be sure to remember the default, you can experiment with the slider, for example try 100 and then 200. Do some rotations and see how the rotations end. It can really improve your videography. Unfortunately, not everyone is able to understand the abstractness of it, so they tend to shy away from it. But, it is a great tool none-the-less.
It is found in the same settings folder as EXPO. It is at the bottom.
Aloha and Drone On! |
