Northofthe49th
just as an example,
when i flew tonight, i raised my Phantom straight above me (or nearly straight above),
anyhow, as i set its orientation roughly to the north, i snapped a pic on my phone, then i physically turned 90 degrees to the east, snapped another pict, then 90 degrees to the south and snapped another pict, again to the west, etc...see the picts attached, i did not touch the Phantoms orientation, just my physical movements!
what you will find is that if you change your physical orientation the screen/radar will change accordingly...ie. if the Phantom is heading straight towards you (arrow towards you) and you physically turn 180 degrees before it gets to you then it is still coming towards you but from behind you...instead of in front of you..and if it is coming towards you and you do not move and it passes you overhead it will then be going away from you/behind you and if your turn at that moment it will still be going away from you but in front of you....you really need to play with it to understand it better...I love the radar, it is how i fly most times when more than a few hundred feet away.... |
